September 20, 2023 at 3:17 pm
Hi Sarah,
The default tempdirectory is specified in the AEDT installation /path/v231/Linux64/config/default.cfg
As you have indicated, this can be overridden by using the batchoption ‘tempdirectory’=’/tmppath'
If the specified folder is not available on the solving computer(s), the solver should revert to system TMP or TMPDIR environment variables.
However, if those also fail, we try using something like: $HOME/Ansoft/.temp
Please
1. confirm all involved execution hosts have the folder you are referencing in your batchoption override.
- also that the specified folder is writable
2. share the contents of //v231/Linux64/config/default.cfg
3. share the top 20 lines from the project.aedt.batchinfo/project_
thanks
Randy
