Rajeshwari Jadhav
You just need to point your application to the server.
First check if are you able to ping or telnet your license server, in the command prompt try using cmd “ping servername” and “telnet servername 1055?
To ON telnet service go to start and search “Turn Windows feature on or off” check box “Telnet Client” and click ok.
Go to the start menu and open the command prompt, and run the below-mentioned commands:
1.            ping servername
type this command and send the screenshot of the output.
2.            telnet servername port_number
The default port number is 1055.
A blank screen will confirm that you are connected, if you get any other output, please provide a screenshot of the same.
