Reno Genest
Is the tied contact between the SPG particles and the FEM ring working? Are the SPG particles (nodes) tied? You can use the Model Checking application in LSPP to check the contacts:
Also, post-process the results only on the ring (show only the ring part in LSPP). Do you see results?
Reno.
