September 21, 2023 at 8:36 am
Hi
You said:
”Basically all I would need is the MAT_117 but I am not sure if this is included in LS-DYNA within the ANSYS workbench.”
This material is or at least should be included in the LS-Dyna system in Workbench (I do not see why it should not) – you just need to define a Keyword Snippet (LS-DYNA) under the relevant part in geometry tree (in the keyword snippet one needs to define the MAT117 material card (C11,etc….)).
See here for an example on a Keyword Snippet (LS-DYNA) MAT definition:
https://forum.ansys.com/forums/topic/import-ls-dyna-mat24-material-card-in-ansys-workbench-and-switch-on-non-linear-properties/
All the best
Erik
