September 21, 2023 at 12:15 pm
- Is this a steady state simulation? Could you please try running it in transient mode?
- Please check the MHD BC to see if they are set up correctly.
- Are the electrical properties for solid updated in material definition?
- Also confirm if the applied values of field through MAG data are correct and data is in correct format.
- Ensure that the conducting material is selected in MHD module
Please check and try these suggestions. Hope this helps!
