September 25, 2023 at 9:32 am
Hi Walaa,
You can edit previously defined animation settings by going to Outline view tab (tab on the left-hand side, one which shows all the settings as a drop-down menu). There go to Solution --> Calculation Activities --> Solution Animations. Here you will the list of animations you have previously defined. You can edit it here.
Thanks & regards
