September 25, 2023 at 3:32 pm
You can calculate the final length of your deformed model, by using probes. From the Result tab select Probe and insert them in the desirable positions to measure the length. You can calculate the length from the Location information sector in Graphics Annotation. Make sure that the coordinate system of your model match the global and the scale is set to True Scale (x1). Hope this helps!
Zoi
