September 25, 2023 at 9:10 pm
Can you translate the first line into english
What operating system are you using.
A way to see your installed fonts is through Control Panel. In Windows 10, go to Control Panel > Fonts.
"On your machine" refers to the machine where you are trying to run and receivng the error.
You can also try:
Open Windows file explorer and go to:
%APPDATA%|Ansys
You will see a directory v232 or a number that corresponds to the version you are running.
Rename that directory to v232.old
Try to run again.
