September 26, 2023 at 7:40 am
Solved!
If somebody else has the similar problem.. For me the solution was to use opengl driver.
On Linux starting from the terminal: fluent -driver opengl
Or set the environment variable: FLUENT_LAUNCHER_OPTIONS=-driver opengl
Source:
https://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node15.htm
