September 26, 2023 at 4:31 pm
Very well, thank you.
I have an additional question. I have a UDF that must be solved in conjunction with the UDS transport equation. The dq/dt is found using the scalar itself. So if I use the C_UDSI to calculate the value of dq/dt, will it work?
