September 29, 2023 at 11:24 am
Hi Sehwa,
I suggest you to refer HFSS help PDF > HFSS Technical Notes > Post Processed S-Matrices > De-embedded S-Matrices in HFSS
As per help document, HFSS ignores attenuation constant and considers only phase constand while performing de-embedding. This implies that, if you are considering a phsycal line of lenght 3 cm and simulating two scenarios of actaul cross section 5 mm and 10 mm and de-embedding the S-parameters.You may find slight gap in both cases if you have a finite conductor and lossy dielectric. Because losses will be different for 5 and 10 mm line length.
I hope this helps.
Thanks.
