October 2, 2023 at 2:08 pm
Dear Federico,
And should I use both at the same time, first shared and then forced shared if I don't have perfect geometry? So most bodies are perfectly in contact, so shared topology is enough, but there may be some bodies in the assembly where there are small gaps or intersections.
Also, regardless of whether shared topology is set in Spaceclaim, the Watertight geometry workflow still automatically suggests Shared Topology. Should I just ignore this and set it to off or does this mean that the software has detected a contact that has not yet been applied shared topology?
Thank you!
