pv00170
When I try to run it using PyFluent (script) instead of the HPC (Sbatch + script) it works well.
The pyFluent script is similar:
import ansys.fluent.core as pyfluent
solver = pyfluent.launch_fluent(precision=”double”, version=”2d”, processor_count=6, mode=”solver”)
solver.tui.file.read_case(‘URANS.cas.h5’)
solver.tui.file.read_data(‘URANS.dat.h5’)
solver.tui.define.models.unsteady_2nd_order(“yes”)
solver.tui.solve.dual_time_iterate(1, 2)
solver.tui.file.write_case(‘Results.cas.h5’, overwrite=True)
solver.tui.file.write_data(‘Results.dat.h5’, overwrite=True)
print(“Done!”)
The only difference is that HPC fails to compile whereas pyFluent works.
