October 3, 2023 at 11:26 am
Hi Christian,
Ansys employees can not run the codes they get on the forum, but I would recommend you to take the snippet that I shared and create some bodies randomly in your model and see if the bounding box method works, please note it will also select the faces if they are partially inside the bounding box.
