Missy Ji
You can increase Controls > Wrapup Criteria, cycle limit to a larger number, it is the maximum number of cycles you want your problem to run (enter a large integer if you don't want your problem to stop on a cycle limit). Your run stops at  99,999 which is correct based on the Wrapup Criteria, cycle limit defined.
The simulation will stop if any one of the Wrapup criteria is met, Cycle limit, Time limit, energy fraction, or other errors happen.
