October 3, 2023 at 9:40 pm
Hi Lucio,
I can take a look at this. I believe you have left a portion of the script at the beginning where x1 through x8 are defined. Would you be able to share the full script? And also if you are using the script to setup the monitor, then please share that as well. If not, you can just share a screenshot of the geometry tab of the monitor. This would help me reproduce the issue and we can get to the root much sooner. Thank you!
Amrita
