October 5, 2023 at 7:14 pm
Hello Takabayashi,
Please try the following:
fini
/cle
C*******************************************************************************
C*** PARAMETERS OUTSIDE OF DO LOOP
height = 20*1e-6
thickness = 3*1e-6
separation = 10*1e-6
width_0 = (100*1e-6) ! INITIAL (STARTING) ELECTRODE WIDTH
d_width = 1e-6 ! INCREMENTAL CHANGE IN ELECTRODE WIDTH
n_width = 5 ! NUMBER OF ELECTRODE WIDTH CASES TO INVESTIGATE
*dim,C_results,,n_width,4 ! ARRAY INTO WHICH CAPACITANCE RESULTS WILL BE SAVED
eps0=8.854e-12 ! FREE SPACE PERMITTIVITY
d_dmn = 10*1e-6 ! DEPTH SURROUNDING DOMAIN EXTENDS BEYOND ELECTRODES
d_inf = 5*1e-6 ! DEPTH OF INFINITE BOUNDARY ELEMENT MESH
esz = 3*1e-6 ! MESH SIZE
V = 0.01 ! APPLIED VOLTAGE
C*** DO LOOP
*do,i,0,n_width-1 ! LOOP OVER ELECTRODE WIDTH
pars,all ! SAVE ALL PARAMETERS TO file.parm
fini ! CLEAR MAPDL DATABBASE (THIS DELETES THE PARAMETERS, TOO!)
/cle
parr ! RESTORE PARAMETERS FROM file.parm TO MAPDL DATABASE
width = width_0 + i*d_width ! ELECTRODE WIDTH FOR ith PASS THROUGH DO LOOP
/title,WIDTH = %width%
/vie,1,1,1,1
/sys,del file*.png
/PREP7
C*** Configured for electrostatic analysis of 3D 8-node elements
ET,1,SOLID123
C*** Define infinite element
ET,2,111,2,1
C*** Material properties (relative dielectric constant in vacuum)
MP,PERX,1,1 ! RELATIVE PERMITTIVITY INSTEAD
C*** Create your first plate
BLOCK,0,width,0,height,0,-thickness
cm,electrode1_a,area
C*** Create second plate
asel,none
BLOCK,0,width,0,height,separation,separation+thickness
cm,electrode2_a,area
C*** SURROUNDING DOMAIN
alls
cm,scrap1_v,volu
*get,xmin,kp,,mnloc,x
*get,xmax,kp,,mxloc,x
*get,ymin,kp,,mnloc,y
*get,ymax,kp,,mxloc,y
*get,zmin,kp,,mnloc,z
*get,zmax,kp,,mxloc,z
vsel,none
bloc,xmin-d_dmn,xmax+d_dmn,ymin-d_dmn,ymax+d_dmn,zmin-d_dmn,zmax+d_dmn
cm,scrap2_v,volu
alls
vsbv,scrap2_v,scrap1_v
C*** MESH
esiz,esz
vmes,all
C*** ELECTRODE VOLTAGE
da,electrode1_a,volt
da,electrode2_a,volt,V
fini
C*** SOLVE
/solu
alls
save
solv
fini
C*** POST PROCESS
/post1
set ! READ RESULTS INTO MADL DATABASE
etab,w,sene ! BASED ON ENERGY
ssum
*get,Wnet,ssum,,item,w
C1 = 2*Wnet/(V**2)
nsel,s,d,volt ! BASED ON CHARGE & VOLTAGE
fsum
*get,q,fsum,,item,chrg
c2 = q/v
C_nominal=eps0*(height*width)/separation ! NOMINAL FRINGE FREE VALUE
/tla,-0.35,0.90,Capacitance (ANSYS, energy) = %C1% Fd ! ANNOTATION
/tla,-0.35,0.85,Capacitance (ANSYS, Q/V) = %C2% Fd
/tla,-0.35,0.80,Capacitance (nominal fringe-free) = %C_nominal% Fd
alls ! CAPPED SECTION PLOTS
wpro,,,90
wpof,,,width/2
/type,1,7
/cpl,1
plns,volt
/sho,png $plns,volt $/sho,close $/wait,2
plve,ef,,,,vect,,on
/sho,png $plve,ef,,,,vect,,on $/sho,close $/wait,2
C_results(i+1,1)=width ! SAVE RESULTS IN C_results ARRAY
C_results(i+1,2)=C_nominal
C_results(i+1,3)=C1
C_results(i+1,4)=C2
*enddo ! END DO LOOP
C*** WRITE C_results ARRAY TO results.txt TEXT FILE
*cfopen,results,txt
*vwrite
(' Width C_nominal C_ANSYS (Energy) C_ANSYS (Terminal Conditions)')
*vwrite,C_results(1,1),C_results(1,2),C_results(1,3),C_results(1,4)
(4X,E16.8,4X,E16.8,4X,E16.8,4X,E16.8)
*cfclose
pars,all
save
/eof
