Frederico Ricca
Hi, I'm a student working on my thesis. My job is to develop a numeric tool to simulate the squeeze flow of an adhesive, similar to the initial problem on this page. Does anyone knows if it is possible to do this simulation without FSI? (Regarding only the fluid deformation and thickness variation). The velocity of the moving upper wall causing the fluid motion would be 0.1 mm/s and the inital thickness 2 mm. The objetive is to evaluate the flow once untill thickness = 1mm.
