Handon Um
Thanks for your kind reply.
First, I set a result from PVlighthouse's calculator (OPAL2) as a reference. And the trend is similar between the reference and my FDTD results.
So I can be confident with my FDTD results.
The problem is the RCWA results. It's quite different from the reference and FDTD results.
I found the index results and material fitting are okay.
Why do the current RCWA results differ from FDTD?
Also, I checked the link so that you can download my files.
RCWA: https://drive.google.com/file/d/1Y6KB5FzyHkrw02NlFsnB8AUykna4fW3q/view?usp=sharing
FDTD: https://drive.google.com/file/d/17Z0xKsg4beiLttKTG4WpC0HpMSM9u95Q/view?usp=sharing
