Hemantg_17
Set an angle of attack by following the various aerofoil courses available on Ansys Innovation Space. Different contours, such as static pressure contours and velocity contours, can be plotted along the aerofoil geometry. Additinonally you can change the AOA by using parametric tool and check for required output values. Chekout the following courses:
Flow over an Airfoil using Ansys Workbench | Ansys Courses
Post Processing of an FSAE Car Simulation| Ansys Innovation Courses
External Flow Example: High-Lift Devices | Ansys Innovation Courses
