October 10, 2023 at 4:37 am
No mam i am running the same file for different wavelengths.Like i set source start freq=360nm and end freq=420nm.Then i add monitors and instead of global monitor settings i use override global monior settings with two frequency points .And then i put my file on simulation.Once done i can see the results on freq1 first and then using sliderĀ against lamda i can see the results for freq 2 as my monitors are saving results for both freq points .Now my intent is to see bth frequency results on the same image so that i can differentiate b/w them just like in hold off we can see multiple plots on single plot.I hope this will work.
