October 10, 2023 at 4:51 pm
Hi Yin,
You can use the Add button to add additional vias. The Configure Vias is only available for Compact PCB type. You will only get lumped PCB and Vias with proper material properties. The Via Details will change the effective thermal conductivity. If you want to get the layers of the PCB, you will need to use the Detailed PCB type. Thanks.
