October 11, 2023 at 5:23 am
Hey there,
To assign materials to parts in Workbench Mechanical using APDL commands, you can indeed use theĀ MATID
command under the geometry. Here's an example command:
! Assuming your material ID is 1 and part number is 2
MP, EX, 1, 2, Youngs_Modulus, Poissons_Ratio
ReplaceĀ Youngs_Modulus
and Poissons_Ratio
with the appropriate numerical values for your material. This command sets the material properties (Young's Modulus and Poisson's Ratio) for material ID 1 assigned to part 2.
Remember to replace the placeholder values with your specific material properties and devops course part numbers.
Hope this helps!
