Guilin Sun
It is doable but a little complicated.
First, you need to know how to run script file in background. please refer to Installing and running Lumerical on Linux without GUI
second, you need to specify the sweep parameters in "model" or structure group. If you want to sweep the layer thickess, you need to use script such as
setnamed("RCWA","interface absolute positions",[-2.25e-7+t1,4.3e-7+t2,1.1e-6+t3]);
where t1,t2, and t3 are the thickness parameters ( I have initial values there) you specify in "Setup" "Script".
please test them before run sweep.
then set the sweep object to sweep the parameters.
finally, you need to write a simple script file with this line:
runsweep;
https://optics.ansys.com/hc/en-us/articles/360034931413-runsweep-Script-command
Other parameters that can be swept can be found by
?getnamed("RCWA").
But you will still need to have available GUI license to run the simulation, though GUI can be not shown.
Please try.
