October 11, 2023 at 10:54 pm
Hi Rijul,
As a general suggestion for your 4-point bending model, I would recommend that you take advantage of symmetry of the geometry and model only half of the geometry. This way, you can apply symmetry boundary conditions to the cut surfaces, and the issue that you're facing should be resolved. Additionally, the computation time of the model will also be significantly reduced by exploiting symmetry of the geometry.
