October 13, 2023 at 11:05 am
Hello Phillip,
Did you try to assign the Lumped RLC boundary to non-rectangular sheets in the eigenmode simulations?
HFSS Help document says "HFSS assumes the lumped RLC is assigned to a rectangular face. If you assign a non-rectangular face, HFSS issues a warning, but proceed with the solution. Using a non-rectangular face can result in less accurate representation of the lumped RLC".
It implies that you can assign the Lumped RLC boundary to non-rectangular sheets also but accuracy will be compromised to some extent.
Hope this will help.
Best Regards
Anchal
