October 13, 2023 at 1:39 pm
Hi Tilen,
There are multiple ways to build the pyramid you need. Here is one approach
You can create a couple of sketches with pentagons. Create one large pentagon and another small one away from the first one. Then use Skin tool to create a solid. Then use Face delete to delete the small face and this will result in the pointed corner at the top
Result of skin from two polygon sketches
Delete the top highlighted face to get the corner
