October 13, 2023 at 2:14 pm
To re-create the liquid supply, apply a "Velocity Inlet" boundary condition to the bottom surface. Check that the velocity and mass flow rates are configured to match the pace of your liquid supply.Set the temperature at the intake to match the liquid's original temperature. You can employ a "Pressure Outlet" or "Outflow" boundary condition for the top surface, where evaporation and heat transfer to the environment occur. Typically, the pressure at this boundary should be indicated in relation to the ambient pressure.
Thank you.
