October 16, 2023 at 9:31 am
You can use selective meshing to check that which part is failing? you can check selective meshing tutorial on you tube, type the keyword "Seelctive meshing in Ansys" and perform this.
Are you able to perform the mesh operation when you change the mesh setting or mesh type?
Sampat
