October 17, 2023 at 3:30 pm
It seems there is no direct script to insert alloy. But you can set some alloy materials that you want to use, and use
addmaterialproperties
to the "materials" folder, and in the "model" you can assign material to a geometry. Using Lumapi to assign the "model".
However the api is not fully developed so please try and see if it works.
