October 18, 2023 at 12:21 pm
Hi Rob, yes thank you for the continuity equilibrium it has the energy source term. So this is just calculated in the model and no manual source term UDF is required?
Added to this, I cant find anything in the theory guide about the S term in the energy equation, for the definition I am after, which is seen below. In this equation Lambda is used instead of Beta for the liquid fraction value. Will this therefore need a UDF and to be added as an energy source term in the porous properties. Thank you
