October 18, 2023 at 5:48 pm
Thank you for the suggestion. I have tried doing this in several different simulations using values of enthalpy of 8.47661e+09 or 8.47660001e+09, and I have found that this seems to create convergence issues and results in a different solution (when compared to the case where I do not specify a value for the higher-temperature enthalpy).
Do you know why this might be the case?
Thank you!
