October 20, 2023 at 7:56 am
Thanks for the specific reply, Niki.
I'm adjusting the mesh settings you mentioned.
Additionally, I want to ask one more thing.
My CHARGE has no problem when I disable the optical generation rate.
I can easily get the dark current result after running the simulation
However, when I enable the optical generation rate, it requires more simulation time, and occurs convergence error.
Is the .mat file that imported into my CHARGE can be one of the reasons for the error?
I ran the FDTD simulation with mesh accuracy = 1 to obtain less data.
Should I check other settings related to FDTD?
