randyk
Hi Ehsan,
Consider basing your script on this example - I highlighted items to watch/change to match your system.
Create "job.sh" with the following contents:
#!/bin/bash
#SBATCH -N 3        # allocate 3 nodes
#SBATCH -n 12       # 12 tasks total
#SBATCH -J AnsysEMTest   # sensible name for the job
#Set job folder, scratch folder, project, and design (Design is optional)
JobFolder=$(pwd)
ProjName=OptimTee-DiscreteSweep-FineMesh.aedt
DsnName="TeeModel:Nominal:Setup1"
# Executable path
AppFolder=//AnsysEM/v222/Linux64
# Copy AEDT Example to $JobFolder for this initial test
cp ${AppFolder}/schedulers/diagnostics/Projects/HFSS/${ProjName} ${JobFolder}/${ProjName}
# setup environments and srun
export ANSYSEM_GENERIC_MPI_WRAPPER=${AppFolder}/schedulers/scripts/utils/slurm_srun_wrapper.sh
export ANSYSEM_COMMON_PREFIX=${AppFolder}/common
export ANSYSEM_TASKS_PER_NODE=${SLURM_TASKS_PER_NODE}
# If enabling Intel MPI 2021 on AEDT 2022R2 to support RHEL8.x (beta flag)
export ANSYSEM_FEATURE_F539685_MPI_INTEL21_ENABLE=1
# setup srun
srun_cmd="srun --overcommit --export=ALL -n 1 --cpu-bind=none --mem-per-cpu=0 --overlap "
# note: srun '--overlap' option was introduced in SLURM VERSION 20.11 - if customer using older SLURM version, remove the "--overlap"
# MPI timeout set to 30min default for cloud suggest lower to 120 or 240 seconds for onprem
export MPI_TIMEOUT_SECONDS=120
# System networking environment variables - HPC system dependent should not be user edits!
# export ANSOFT_MPI_INTERCONNECT=ib
# export ANSOFT_MPI_INTERCONNECT_VARIANT=ofed
# Skip dependency check
export ANS_NODEPCHECK=1
# Setup Batchoptions
echo "\$begin 'Config'" > ${JobFolder}/${JobName}.options
# echo "'Desktop/Settings/ProjectOptions/HPCLicenseType'='Pack'" >> ${JobFolder}/${JobName}.options
echo "'HFSS/RAMLimitPercent'=90" >> ${JobFolder}/${JobName}.options
echo "'HFSS/RemoteSpawnCommand'='scheduler'" >> ${JobFolder}/${JobName}.options
# echo "'Desktop/Settings/ProjectOptions/AnsysEMPreferredSubnetAddress'='192.168.16.0/24'" >> ${JobFolder}/${JobName}.options
echo "\$end 'Config'" >> ${JobFolder}/${JobName}.options
# Run Job
${srun_cmd} ${AppFolder}/ansysedt -ng -monitor -waitforlicense -useelectronicsppe=1 -distributed -auto -machinelist numcores=12 -batchoptions ${JobFolder}/${JobName}.options -batchsolve ${DsnName} ${JobFolder}/${ProjName}
#note the "numcores=xx"  must match the assigned resource core count.
Then run it:
$ dos2unix ./job.sh
$ chmod +x  ./job.sh
$ sbatch ./job.sh
