Caterina Azais
thank you so much, that seems to be making much more sense now... I have changed the code as follows, however when i print the PRNSOL commands it says that the S, D, .. data are not available and hence its ignored. What is the problem? Thank you !
! Geometry
l = 5e-3 ! beam length, m
w = 5e-3 ! electrode width, m
t = 100e-6 ! thickness, m
! Material properties
Y = 140e9 ! Young modulus, Pa
mu=0.358 ! Poisson ratio (nearly incompressible rubber)
eps=8.17 ! electrical permittivity, relative
eps0=8.854e-12 ! free-space permittivity, F/m
/VUP,1,z
/VIEW,1,1,1,1
/PREP7
ET, 1, 5, 3
! == Material parameters
! -- Elastic coefficients, MPa
c11 = 209.71e9
c12 = 121.14e9
c13 = 105.36e9
c33 = 210.9e9
c44 = 42.5e9
c66 = 44.28e9
tb,ANEL,1
tbdata, 1, c11, c12, c13
tbdata, 7, c11, c13
tbdata, 12, c33
tbdata, 16, c66
tbdata, 19, c44
tbdata, 21, c44
! -- Piezoelectric coefficients, pC/um2
e13 = -0.61
e33 = 1.14
e15 = -0.59
tb,PIEZ,1
tbdata, 3, e13
tbdata, 6, e13
tbdata, 9, e33
tbdata,14, e15
tbdata,16, e15
! -- Dielectric constants
emunit,EPZRO,8.854e-6 ! pF/um
mp,PERx,1, 7.57
mp,PERy,1, 7.57
mp,PERz,1, 8.31
! -- model and mesh block
block,-l/2,l/2,-w/2,w/2,0,t
! Set the merging tolerance (adjust as needed)
KETOL = 1.0e-5
vmesh,1
! Structural BC
nsel,s,loc,z,0
d, all, volt, 0
d,all,ux,0
d,all,uy,0
d,all,uz,0
nsel,all
nsel,s,loc,z,t
SF,ALL,PRES,10000 ! APPLY PRESSURE LOAD
NSEL,ALL
FINISH
/SOLVE
OUTPR,,LAST
/OUT,SCRATCH
SOLVE
FINISH
/POST1
/OUT,
PRNSOL,S,COMP
PRNSOL,EPEL,COMP
PRNSOL,EF,COMP
PRNSOL,D,COMP
