Morgan Ramanauskas
Hi Erik,
Thanks for your reply and suggestions. I've enabled weak springs which allows the analysis to run however, the shaft is undergoing rigid body motion at 45 degrees in the XY plane and is moving 9mm under the 1N load. It's like the bearing constrains aren't doing anything.
Kind regards,
MorganĀ
