October 20, 2023 at 3:20 pm
Yes. Heat and Temperature are both meeting the convergence criteria.
Is the model failing to converge? If so, you should review the solver output. In MAPDL, you can save the output to a text file with the '/OUTPUT,filename,ext' command, so you can review the entire solver output history, start to finish. By Default, the output window only displays the last 500 lines and these are not saved to a file. Also, look at the file.err in saved to the working directory for clues as to what is causing the solution to fail, if that is a problem.
