Mike Rife
Emporer
Check the Ansys Mechanical APDL Help on Contact174; the friction coefficient, MU, is an result and is stored in NMISC items, one item for each corner node of the element.  You can use a User Defined Result with the expression NMISCxx where xx is the specific number you will find in the help for the result.  And scope to the contact.
