Ammar Ahmed
Unfortunately it is not same for velocity too. the proper contours are not genertaed as compared to when pressure based inlets are used. As the fluids used are air and water, the density for air is ideal gas based and water's density is theone given in fluent Do you know anyway in which we can calculate velocity from amss flow raets with consideration of pressure as I am currently converting mass flow rate to velocity by formula: mdot =density*veloctiy*area
