Forum Moderator
If you're flowing water into the green section you need to extend the domain and significantly increase the mesh resolution. The above looks like the solver is not happy, and you're basically bouncing off the limiters of temperature as the solution doesn't quite crash. You may also want to look at thin wall options in Fluent as you may not need to consider the plastic as a solid zone.
