October 25, 2023 at 3:48 am
You are welcome! Now if you go to the Script Tab in the Analysis Tab, then you will see the code that is used for calculating "S" and "S-polarization" results.
You can get line numbers that are causing the errors. Find these lines in the Script tab and try to identify what is causing the error.
Amrita
