October 26, 2023 at 10:46 am
Forum Moderator
I'm not sure the DPM droplets do need a nonNewtonian viscosity unless the model is using the same material. I've run so many combinations of DPM/VOF/EWF that I've lost track of which model shares materials...
You've set a parameter expression - I wonder if you're working in the wrong place. Use Named Expressions,
