October 27, 2023 at 12:03 pm
Hello Maji,
A compression test is a very, very, low velocity event, therefore, you solve it using Static Structural where velocity is irrelevant.
The Static Structural solver is more robust when the input is displacement rather than force. Insert into the Solution branch a Probe to extract the Reaction Force from the displacement. In that way, you know the force at every time step.
