Peter Yip
Hi Ian,
It seems the issue is with the Johnson-Holmquist model for solid ALE elements. I'm using ELFORM=11 if that helps diagnose anything here. I've attached a snippet of my terminal with the error. I also am running R12... not the latest release. If you feel like this warrants a ticket, I can place one.
Do you have any workflow documents on how I setup an SPG x ALE coupled simulation?
Thanks,
