Akshay Maniyar
Hi Murali,
If you don’t want blocks then you can create a free-standing remote point and then scope point masses to those remote points. If you want block geometry then you can create a 1m 1m 1m block and assign material with a density as per the mass of the block. You cannot assign a mass value directly for blocks in mechanical.
Thanks,
Akshay maniyar
