Aras karimi
Dear Keyur,
The front surface of the domain is located at the origin of the coordinates, and the back surface of the domain is located in the -Z direction and at a distance of -0.2 meters from the origin of the coordinates. (In other words, the span length of the airfoil is 0.2 meters)
I went to ICEM Help and found the following:
I'm still confused and I don't know what number should I put for the offset ?
If you help me, I will thank you a thousand times.
Regards
