November 1, 2023 at 3:05 pm
Are you using constant density for the water or the compressible fluid formulation? I would suggest first that you use compressible fluid to see if this reduces any potential pressure spikes which may contribute to this floating point error. If that doesn't help, then you should consider using remeshing.
