Muhammad Zeeshan
Hi Dave!
Thanks a lot for your response. I did the same last night. Multiplying the load factor with the bending value from BMD. Don't have the idea to extract BMD or SFD for a solid in ansys hence generated them by hand because all the queries i went through, it says you can't get BMD values for a solid in ansys unless it's defined by a line body.
