Francois Gleyzon
I thought about it, but isn´t there a way of only looking at the corner nodes then. Because from what I understood, I would be able only to get the values of these nodes, so, it is compulsory for me to look only at those node. And this link with my precedent question and the use of this "nsle,s,corner" function. How to be able to only look at these nodes when using the *GET or *VGET function ?
When I used this "nsle,s,corner" function, I had this line in my out put controler :
But I do not have the impression that the funct
SELECT      ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
 CONSIDER ONLY CORNER NODES
      23082 NODES (OF     163848  DEFINED) SELECTED FROM
   108888 SELECTED ELEMENTS BY NSLE COMMAND.
ion afterwards were only looking at these nodes.
