Daniel Shaw
NSEL,S,CORNER should select the corner nodes and *GET should work on the selected set.  So, using selection logic and *GET should enable to access information from a subset of the mdoel.  *VGET works on the entire database.  It does not work only on the selected set.  To use *VGET acess a subset of the model, you need to use a masking vector *VMASK.
